Preprints, Working Papers, ...
T-coercivity for the asymptotic analysis of scalar problems with sign-changing coefficients in thin periodic domains
Abstract : We study a scalar problem in thin periodic composite media formed by two materials, a classical one and a metamaterial (also known as negative material). By applying T-coercivity methods and homogenization techniques specific to the thin periodic domains under consideration, for two geometric settings, we derive the homogenized limit problems, which both exhibit dimension-reduction effects.
Document type :
Complete list of metadatas
Cited literature [50 references]  Display  Hide  Download
https://hal.inria.fr/hal-02974043
Contributor : Karim Ramdani <>
Submitted on : Wednesday, October 21, 2020 - 3:03:23 PM
Last modification on : Friday, December 4, 2020 - 3:29:21 PM
File
Bun-Ram-Tim-Submitted.pdf
Identifiers
  • HAL Id : hal-02974043, version 1
Collections
Citation
Renata Bunoiu, Karim Ramdani, Claudia Timofte. T-coercivity for the asymptotic analysis of scalar problems with sign-changing coefficients in thin periodic domains. 2020. ⟨hal-02974043⟩
Share
Metrics
Record views
83
Files downloads
107
