Distribution of 137cs in rat tissues after various schedules of chronic ingestion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin de l'Association des archivistes de l'Église de France Année : 2010
The aim of this work was to compare the distribution of 137Cs in organisms after chronic ingestion following different schedules. Rats were contaminated through drinking water containing 6,500 Bq L-1 of 137Cs, starting either at birth, at weaning, or upon reaching adult age (13 wk). Animals were then sacrificed after different durations of ingestion. 137Cs content of organs and excreta were determined by γ counting. A slight decrease in Cs elimination through urine was observed according to the age of animals. All organs tested showed similar 137Cs content, with the exception of striated muscles and the thyroid at certain ages, which showed the highest accumulation of Cs. The lowest 137Cs concentration was found in the blood, which acts as a transfer compartment after absorption in the intestine. Substructures of the central nervous system showed a homogeneous level of 137Cs accumulation, except for the olfactive bulbs. In these structures, an increased concentration of 137Cs was observed, suggesting a possible direct route of intake through the nasal epithelium. Overall, these results are in agreement with current models for the biokinetics of 137Cs. However, these results also suggest that the thyroid should be taken into account in future models of 137Cs biokinetics. Copyright © 2010 Health Physics Society.
Fichier non déposé
hal-02974261 , version 1 (21-10-2020)
E. Tourlonias, J.-M. Bertho, R. Gurriaran, P. Voisin, F. Paquet. Distribution of 137cs in rat tissues after various schedules of chronic ingestion. Bulletin de l'Association des archivistes de l'Église de France, 2010, 99 (1), pp.39-48. ⟨10.1097/HP.0b013e3181d4f00e⟩. ⟨hal-02974261⟩
19 Consultations
0 Téléchargements
