Similarity-based prediction for channel mapping and user positioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In a wireless network, gathering information at the base station about mobile users based only on uplink channel measurements is an interesting challenge. Indeed, accessing the users locations and predicting their downlink channels would be particularly useful in order to optimize the network efficiency. In this paper, a supervised machine learning approach addressing these tasks in an unified way is proposed. It relies on a labeled database that can be acquired in a simple way by the base station while operating. The proposed regression method can be seen as a computationally efficient two layers neural network initialized with a non-parametric estimator. It is illustrated on realistic channel data, both for the positioning and channel mapping tasks, achieving better results than previously proposed approaches, at a lower cost.
sim_based_pred.pdf (219.76 Ko) Télécharger le fichier
hal-02974852 , version 1 (22-10-2020)
hal-02974852 , version 2 (01-12-2020)
hal-02974852 , version 3 (05-01-2021)
Luc Le Magoarou. Similarity-based prediction for channel mapping and user positioning. 2020. ⟨hal-02974852v2⟩
118 Consultations
237 Téléchargements
