Final size and convergence rate for an epidemic in heterogeneous population - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2021
We formulate a general SEIR epidemic model in a heterogenous population characterized by some trait in a discrete or continuous subset of a space R d. The incubation and recovery rates governing the evolution of each homogenous subpopulation depend upon this trait, and no restriction is assumed on the contact matrix that defines the probability for an individual of a given trait to be infected by an individual with another trait. Our goal is to derive and study the final size equation fulfilled by the limit distribution of the population. We show that this limit exists and satisfies the final size equation. The main contribution is to prove the uniqueness of this solution among the distributions smaller than the initial condition. We also establish that the dominant eigenvalue of the next-generation operator (whose initial value is equal to the basic reproduction number) decreases along every trajectory until a limit smaller than 1. The results are shown to remain valid in presence of diffusion term. They generalize previous works corresponding to finite number of traits (including metapopulation models) or to rank 1 contact matrix (modeling e.g. susceptibility or infectivity presenting heterogeneity independently of one another).
m3as_Heterogeneous_revised_Hal.pdf (307.44 Ko) Télécharger le fichier
hal-02981952 , version 1 (28-10-2020)
hal-02981952 , version 2 (01-03-2023)
Luís Almeida, Pierre-Alexandre Bliman, Grégoire Nadin, Benoît Perthame, Nicolas Vauchelet. Final size and convergence rate for an epidemic in heterogeneous population. Mathematical Models and Methods in Applied Sciences, 2021, 31 (05), pp.1021-1051. ⟨hal-02981952v2⟩
240 Consultations
154 Téléchargements
