A complementarity approach for the computation of periodic oscillations in piecewise linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Dynamics Année : 2016
Piecewise linear (PWL) systems can exhibit quite complex behaviours. In this paper, the com-plementarity framework is used for computing periodic steady-state trajectories belonging to linear time-invariant systems with PWL, possibly set-valued, feedback relations. The computation of the periodic solutions is formulated in terms of a mixed quadratic com-plementarity problem. Suitable anchor equations are used as problem constraints in order to determine the unknown period and to fix the phase of the steady-state oscillation. The accuracy of the complementarity problem solution is shown through numerical investigations of stable and unstable oscillations exhibited by practical PWL systems: a neural oscillator, a deadzone feedback system, a stick-slip system, a repressilator and a relay feedback system.
sessa2016-author.pdf (993.26 Ko) Télécharger le fichier
hal-02982668 , version 1 (28-10-2020)
hal-02982668 , version 2 (29-10-2020)
Valentina Sessa, Luigi Iannelli, Francesco Vasca, Vincent Acary. A complementarity approach for the computation of periodic oscillations in piecewise linear systems. Nonlinear Dynamics, 2016, ⟨10.1007/s11071-016-2758-5⟩. ⟨hal-02982668v1⟩
132 Consultations
145 Téléchargements
