Sharpness, Restart and Acceleration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Optimization Année : 2020
The Łojasiewicz inequality shows that sharpness bounds on the minimum of convex optimization problems hold almost generically. Sharpness directly controls the performance of restart schemes, as observed by Nemirovskii and Nesterov [1985]. The constants quantifying these sharpness bounds are of course unobservable , but we show that optimal restart strategies are robust, in the sense that, in some important cases, finding the best restart scheme only requires a log scale grid search. Overall then, restart schemes generically accelerate accelerated first-order methods.
1702.03828.pdf (359.08 Ko) Télécharger le fichier
hal-02983236 , version 1 (29-10-2020)
Vincent Roulet, Alexandre d'Aspremont. Sharpness, Restart and Acceleration. SIAM Journal on Optimization, 2020, 30 (1), pp.262-289. ⟨10.1137/18M1224568⟩. ⟨hal-02983236⟩
2028 Consultations
158 Téléchargements
