Fast and Robust Stability Region Estimation for Nonlinear Dynamical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
A linear quadratic regulator can stabilize a nonlinear dynamical system with a local feedback controller around a linearization point, while minimizing a given performance criteria. An important practical problem is to estimate the region of attraction of such a controller, that is, the region around this point where the controller is certified to be valid. This is especially important in the context of highly nonlinear dynamical systems. In this paper, we propose two stability certificates that are fast to compute and robust when the first, or second derivatives of the system dynamics are bounded. Associated with an efficient oracle to compute these bounds, this provides a simple stability region estimation algorithm compared to classic approaches of the state of the art. We experimentally validate that it can be applied to both polynomial and non-polynomial systems of various dimensions, including standard robotic systems, for estimating region of attractions around equilibrium points, as well as for trajectory tracking.
Regions_of_attraction.pdf (2.34 Mo) Télécharger le fichier
hal-02984348 , version 1 (30-10-2020)
hal-02984348 , version 2 (02-09-2021)
  • HAL Id : hal-02984348 , version 1
Eloïse Berthier, Justin Carpentier, Francis Bach. Fast and Robust Stability Region Estimation for Nonlinear Dynamical Systems. 2020. ⟨hal-02984348v1⟩
2777 Consultations
415 Téléchargements
