Set inversion under functional uncertainties with joint meta-models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper we propose an efficient sampling strategy to solve inversion problem under functional uncertainty. This approach aims to characterize region of a control space defined by exceedance above prescribed threshold. This study is motivated by an application on identifying the set of control parameters leading to meet the pollutant emission standards of a vehicle under driving profile uncertainties. In that context, the constrained response in the inversion problem is here formulated as the expectation over the functional random variable only known through a set of realizations and the unknown set is thus associated with the control variables. As often in industrial applications, this problem involves high-fidelity and time-consuming computational models. We thus proposed an approach that makes use of Gaussian Process meta-models built on the joint space of control and uncertain input variables. Specifically, we define a design criterion based on uncertainty in the excursion of the Gaussian Process and derive tractable expressions for the variance reduction in such a framework. Applications to analytical examples, followed by the automotive industrial test case show the accuracy and the efficiency brought by the proposed procedure.
2020_ElAmri_SIAMUQ_soumis.pdf (1.21 Mo) Télécharger le fichier
hal-02986558 , version 1 (03-11-2020)
hal-02986558 , version 2 (30-09-2021)
hal-02986558 , version 3 (25-05-2023)
hal-02986558 , version 4 (13-07-2023)
hal-02986558 , version 5 (20-07-2023)
  • HAL Id : hal-02986558 , version 1
Reda El Amri, Céline Helbert, Miguel Munoz Zuniga, Clémentine Prieur, Delphine Sinoquet. Set inversion under functional uncertainties with joint meta-models. 2020. ⟨hal-02986558v1⟩
649 Consultations
324 Téléchargements
