Probabilistic reachability and control synthesis for stochastic switched systems using the tamed Euler method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2020
In this paper, we explain how, under the one-sided Lipschitz (OSL) hypothesis, one can find a mean square error bound for a variant of the Euler-Maruyama approximation method for stochastic switched systems. Subsequently, we explain how this bound can be used to control a stochastic switched system in order to make it reach a target zone with guaranteed minimum probability. The method is illustrated on several examples from the literature.
lecoent2020probabilistic.pdf (1.39 Mo) Télécharger le fichier
hal-02987885 , version 1 (04-11-2020)
Adrien Le Coënt, Laurent Fribourg, Jonathan Vacher, Rafael Wisniewski. Probabilistic reachability and control synthesis for stochastic switched systems using the tamed Euler method. Nonlinear Analysis: Hybrid Systems, 2020, 36 (100860), ⟨10.1016/j.nahs.2020.100860⟩. ⟨hal-02987885⟩
66 Consultations
119 Téléchargements
