A Study of F0 Modification for X-Vector Based Speech Pseudo-Anonymization Across Gender - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
Speech pseudo-anonymization aims at altering a speech signal to map the identifiable personal characteristics of a given speaker to another identity. In other words, it aims to hide the source speaker identity while preserving the intelligibility of the spoken content. This study takes place in the VoicePrivacy 2020 challenge framework, where the baseline system performs pseudo-anonymization by modifying x-vector information to match a target speaker while keeping the fundamental frequency (F0) unchanged. We propose to alter other paralin-guistic features, here F0, and analyze the impact of this modification across gender. We found that the proposed F0 modification always improves pseudo-anonymization. We observed that both source and target speaker genders affect the performance gain when modifying the F0.
SLT_2021.pdf (456.32 Ko) Télécharger le fichier
hal-02995862 , version 1 (09-11-2020)
hal-02995862 , version 2 (21-01-2021)
  • HAL Id : hal-02995862 , version 1
Pierre Champion, Denis Jouvet, Anthony Larcher. A Study of F0 Modification for X-Vector Based Speech Pseudo-Anonymization Across Gender. [Research Report] INRIA Nancy, équipe Multispeech. 2020. ⟨hal-02995862v1⟩
328 Consultations
338 Téléchargements
