Performance Impact Analysis of Security Attacks on Cross-Layer Routing Protocols in Vehicular Ad hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently, several cross-layer protocols have been designed for vehicular networks to optimize data dissemination by ensuring internal communications between routing and MAC layers. In this context, a cross-layer protocol, called TDMA-aware Routing Protocol for Multi-hop communications (TRPM), was proposed in order to efficiently select a relay node based on time slot scheduling information obtained from the MAC layer. However, due to the constant evolution of cyber-attacks on the routing and MAC layers, data dissemination in vehicular networks is vulnerable to several types of attack. In this paper, we identify the different attack models that can disrupt the cross-layer operation of the TRPM protocol and assess their impact on performance through simulation. Several new vulnerabilities related to the MAC slot scheduling process are identified. Exploiting of these vulnerabilities would lead to severe channel capacity wastage where up to half of the free slots could not be reserved.
Performance__Impact__Analysis__of__Security__Attacks__on__Cross_Layer__Routing__Protocols__in__Vehicular__Ad__hoc__Networks_Camera_Ready_Softcom.pdf (367.76 Ko) Télécharger le fichier
hal-02996797 , version 1 (09-11-2020)
  • HAL Id : hal-02996797 , version 1
Sihem Baccari, Haifa Touati, Mohamed Hadded, Paul Mühlethaler. Performance Impact Analysis of Security Attacks on Cross-Layer Routing Protocols in Vehicular Ad hoc Networks. SoftCom 2020 - International Conference on Software, Telecommunications and Computer Networks, Sep 2020, Hvar / Virtual, Croatia. ⟨hal-02996797⟩
Collections
INRIA INRIA2
151 Consultations
235 Téléchargements
