How to use Model Checking for Diagnosing Fault Patterns in Petri nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the problem of fault pattern diagnosis in discrete event systems modelled by Petri nets. A general framework for implementing a pattern diagnosis function by model-checking is proposed. Two different approaches with experimental results are presented and compared to a third approach from the literature.
article_proceedings_0056.pdf (371.5 Ko) Télécharger le fichier
hal-02997908 , version 1 (10-11-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-02997908 , version 1
Johanne Bakalara, Yannick Pencolé, Audine Subias. How to use Model Checking for Diagnosing Fault Patterns in Petri nets. WODES 2020 - 15th IFAC Workshop on Discrete Event Systems, Nov 2020, Virtual, Brazil. pp.1-6. ⟨hal-02997908⟩
77 Consultations
86 Téléchargements
