C source-to-source compiler enhancement from within
Amélioration source-à-source de compilateurs C
We show how locally replaceable code snippets can be used to easily
specify and prototype compiler and language enhancements for the
C language that work by local source-to-source
transformation.
A toolbox implements the feature and provides many directives that
can be used for compile time configuration and tuning, code
unrolling, compile time expression evaluation and program
modularization.
The tool is also easily extensible by simple filters that can be
programmed with any suitable text processing framework.
