On the stability of equilibrium preserving spectral methods for the homogeneous Boltzmann equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics Letters Année : 2021
Spectral methods, thanks to the high accuracy and the possibility to use fast algorithms, represent an effective way to approximate the Boltzmann collision operator. On the other hand, the loss of some local invariants leads to the wrong long time behavior. A way to overcome this drawback, without sacrificing spectral accuracy, has been proposed recently with the construction of equilibrium preserving spectral methods. Despite the ability to capture the steady state with arbitrary accuracy, the theoretical properties of the method have never been studied in details. In this paper, using the perturbation argument developed by Filbet and Mouhot for the homogeneous Boltzmann equation, we prove stability, convergence and spectrally accurate long time behavior of the equilibrium preserving approach.
EquilibriumPreserving_note.pdf (136.6 Ko) Télécharger le fichier
hal-03000138 , version 1 (11-11-2020)
Lorenzo Pareschi, Thomas Rey. On the stability of equilibrium preserving spectral methods for the homogeneous Boltzmann equation. Applied Mathematics Letters, 2021, 120, pp.107187. ⟨10.1016/j.aml.2021.107187⟩. ⟨hal-03000138⟩
50 Consultations
58 Téléchargements
