Predicted success of prophylactic antiviral therapy to block or delay SARS-CoV-2 infection depends on the drug's mechanism of action - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Antonio Gonçalves
Olivier Tenaillon
Alan S Perelson
  • Fonction : Auteur
Jérémie Guedj
François Blanquart
Repurposed drugs that are immediately available and safe to use constitute a first line of defense against new viral infections. Despite limited antiviral activity against SARS-CoV-2, several drugs are being tested as medication or as prophylaxis to prevent infection. Using a stochastic model of early phase infection, we find that a critical efficacy above 87% is needed to block viral establishment. This can be improved by combination therapy. Below the critical efficacy, establishment of infection can sometimes be prevented, most effectively with drugs blocking viral entry into cells or enhancing viral clearance. Even when a viral infection cannot be prevented, antivirals delay the time to detectable viral loads. This delay flattens the within-host viral dynamic curve, possibly reducing transmission and symptom severity. Thus, antiviral prophylaxis, even with reduced efficacy, could be efficiently used to prevent or alleviate infection in people at high risk.
2020.05.07.20092965v2.full.pdf (486.52 Ko) Télécharger le fichier
hal-03003001 , version 2 (13-11-2020)
hal-03003001 , version 1 (13-11-2020)
hal-03003001 , version 3 (23-11-2020)
Peter Czuppon, Florence Débarre, Antonio Gonçalves, Olivier Tenaillon, Alan S Perelson, et al.. Predicted success of prophylactic antiviral therapy to block or delay SARS-CoV-2 infection depends on the drug's mechanism of action. 2020. ⟨hal-03003001v1⟩
228 Consultations
97 Téléchargements
