Distributed Loop Computer-Networks: A Survey - Archive ouverte HAL Access content directly
Journal Articles Journal of Parallel and Distributed Computing Year : 1995
(1) , (2) , (3)
1
2
3
Distributed loop computer nerworks are extensions of the ring networks and are widely used in the design and implementation of local area networks and parallel processing architectures. We give a survey of recent results on this class of interconnection networks. We pay special attention to the actual computation of the minimun diameter and the construction of lopp networks which can achieve this optimal number. Some open problems are offered for futher investigation.
74-BCH95-surveyloops.pdf (4.15 Mo) Télécharger le fichier
Dates and versions
hal-03013440 , version 1 (18-11-2020)
Identifiers
Cite
Jean-Claude Bermond, Francesco Comellas, D.Frank Hsu. Distributed Loop Computer-Networks: A Survey. Journal of Parallel and Distributed Computing, 1995, 24 (1), pp.2-10. ⟨10.1006/jpdc.1995.1002⟩. ⟨hal-03013440⟩
28 View
60 Download
Share
