CAS: corpus of clinical cases in French - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biomedical Semantics Année : 2020
Background: Textual corpora are extremely important for various NLP applications as they provide information necessary for creating, setting and testing those applications and the corresponding tools. They are also crucial for designing reliable methods and reproducible results. Yet, in some areas, such as the medical area, due to confidentiality or to ethical reasons, it is complicated or even impossible to access representative textual data. We propose the CAS corpus built with clinical cases, such as they are reported in the published scientific literature in French. Results: Currently, the corpus contains 4,900 clinical cases in French, totaling nearly 1.7M word occurrences. Some clinical cases are associated with discussions. A subset of the whole set of cases is enriched with morpho-syntactic (PoS-tagging, lemmatization) and semantic (the UMLS concepts, negation, uncertainty) annotations. The corpus is being continuously enriched with new clinical cases and annotations. The CAS corpus has been compared with similar clinical narratives. When computed on tokenized and lowercase words, the Jaccard index indicates that the similarity between clinical cases and narratives reaches up to 0.9727. Conclusion: We assume that the CAS corpus can be effectively exploited for the development and testing of NLP tools and methods. Besides, the corpus will be used in NLP challenges and distributed to the research community.
s13326-020-00225-x.pdf (1.12 Mo) Télécharger le fichier
hal-03021064 , version 1 (24-11-2020)
Natalia Grabar, Clément Dalloux, Vincent Claveau. CAS: corpus of clinical cases in French. Journal of Biomedical Semantics, 2020, ⟨10.1186/s13326-020-00225-x⟩. ⟨hal-03021064⟩
103 Consultations
147 Téléchargements
