Martingale Wasserstein inequality for probability measures in the convex order - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bernoulli Année : 2022
It is known since [24] that two one-dimensional probability measures in the convex order admit a martingale coupling with respect to which the integral of $\vert x-y\vert$ is smaller than twice their $\mathcal W_1$-distance (Wasserstein distance with index $1$). We showed in [24] that replacing $\vert x-y\vert$ and $\mathcal W_1$ respectively with $\vert x-y\vert^\rho$ and $\mathcal W_\rho^\rho$ does not lead to a finite multiplicative constant. We show here that a finite constant is recovered when replacing $\mathcal W_\rho^\rho$ with the product of $\mathcal W_\rho$ times the centred $\rho$-th moment of the second marginal to the power $\rho-1$. Then we study the generalisation of this new stability inequality to higher dimension.
hal-03021483 , version 1 (24-11-2020)
Benjamin Jourdain, William Margheriti. Martingale Wasserstein inequality for probability measures in the convex order. Bernoulli, 2022, 28 (2), pp.830-858. ⟨10.3150/21-bej1368⟩. ⟨hal-03021483⟩
101 Consultations
0 Téléchargements
