Separation of periods of quartic surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algebra & Number Theory Année : 2023
The periods of a quartic surface X are complex numbers obtained by integrating a holomorphic 2-form over 2-cycles in X. For any quartic X defined over the algebraic numbers and any 2-cycle G in X, we give a computable positive number c(G) such that the associated period A satisfies either |A| > c(G) or A = 0. This makes it possible in principle to certify a part of the numerical computation of the Picard group of quartics and to study the Diophantine properties of periods of quartics.
periodgap.pdf (574.37 Ko) Télécharger le fichier
hal-03022612 , version 1 (24-11-2020)
hal-03022612 , version 2 (01-12-2020)
Pierre Lairez, Emre Can Sertöz. Separation of periods of quartic surfaces. Algebra & Number Theory, 2023, 17 (10), pp.1753-1778. ⟨10.2140/ant.2023.17.1753⟩. ⟨hal-03022612v2⟩
59 Consultations
71 Téléchargements
