Opinion Dynamics with Topological Gossiping: Asynchronous Updates under Limited Attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Control Systems Letters Année : 2020
Wilbert Samuel Rossi
  • Fonction : Auteur
  • PersonId : 1083672
Paolo Frasca
This paper introduces a general model of opinion dynamics with opinion-dependent connectivity. Agents update their opinions asynchronously: for the updating agent, the new opinion is the average of the k closest opinions within a subset of m agents that are sampled from the population of size n. Depending on k and m with respect to n, the dynamics can have a variety of equilibria, which include consensus and clustered configurations. The model covers as special cases a classical gossip update (if m = n) and a deterministic update defined by the k nearest neighbors (if m = k). We prove that the dynamics converges to consensus if n > 2(m − k). Before convergence, however, the dynamics can remain for long time in the vicinity of metastable clustered configurations.
root-final.pdf (462.56 Ko) Télécharger le fichier
hal-03032710 , version 1 (01-12-2020)
Wilbert Samuel Rossi, Paolo Frasca. Opinion Dynamics with Topological Gossiping: Asynchronous Updates under Limited Attention. IEEE Control Systems Letters, 2020, 4 (3), pp.566-571. ⟨10.1109/LCSYS.2020.2974822⟩. ⟨hal-03032710⟩
72 Consultations
123 Téléchargements
