On the Optimality of the Kitanidis Filter for State Estimation Rejecting Unknown Inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2021
As a natural extension of the Kalman filter to systems subject to arbitrary unknown inputs, the Kitanidis filter has been designed by one-step minimization of the trace of the state estimation error covariance matrix. In this technical communiqué, it is shown that the Kitanidis filter is also optimal for the whole gain sequence in the sense of matrix positive definiteness, which notably implies that the Kitanidis filter minimizes not only the trace criterion, but also the matrix spectral norm criterion.
kitanidis_optimality.pdf (272.95 Ko) Télécharger le fichier
hal-03041232 , version 1 (04-12-2020)
hal-03041232 , version 2 (01-08-2021)
Bernard Delyon, Qinghua Zhang. On the Optimality of the Kitanidis Filter for State Estimation Rejecting Unknown Inputs. Automatica, 2021, 132, pp.article n°109793. ⟨10.1016/j.automatica.2021.109793⟩. ⟨hal-03041232v2⟩
335 Consultations
247 Téléchargements
