Fully structured proof theory for intuitionistic modal logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a labelled sequent system and a nested sequent system for intuitionistic modal logics equipped with two relation symbols, one for the accessibility relation associated with the Kripke semantics for modal logics and one for the preorder relation associated with the Kripke semantics for intuitionistic logic. Both systems are in close correspondence with the bi-relational Kripke semantics for intuitionistic modal logic.
aiml20.pdf (315.56 Ko) Télécharger le fichier
hal-03048959 , version 1 (09-12-2020)
  • HAL Id : hal-03048959 , version 1
Sonia Marin, Marianela Morales. Fully structured proof theory for intuitionistic modal logics. AiML 2020 - Advances in Modal Logic, Aug 2020, Helsinki, Finland. ⟨hal-03048959⟩
100 Consultations
183 Téléchargements
