MOILab: towards a labelled theorem prover for intuitionistic modal logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We present MOILab, a prototype Prolog theorem prover implementing a labelled sequent calculus for IK, the basic system in the intuitionistic modal logics family. MOILab builds upon MOIN, a theorem prover implementing nested sequent calculi (both single-conclusion and multi-conclusion) for all the logics in the modal intuitionistic cube. With respect to the nested implementations, MOILab offers a straightforward countermodel construction in case of proof search failure.
WiL_moiLab.pdf (307.36 Ko) Télécharger le fichier
hal-03048966 , version 1 (09-12-2020)
  • HAL Id : hal-03048966 , version 1
Marianna Girlando, Marianela Morales. MOILab: towards a labelled theorem prover for intuitionistic modal logics. 2020. ⟨hal-03048966⟩
71 Consultations
81 Téléchargements
