In the upright stance, posture is better controlled to perform precise visual tasks than laser pointing tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Applied Physiology Année : 2021
Purpose. In the upright stance, young adults better stabilize their posture when they perform precise visual or pointing movements than when they stand quietly. We tested if postural stability could be improved further if the precise and pointing tasks were combined. Method. Twenty-four healthy young adults (22±12 years) performed six tasks combining three visual tasks (precise search, unprecise free-viewing and fixation tasks) and two pointing tasks (pointing-on and pointing-off tasks with laser beam on and off, respectively). In the visual tasks, participants either searched to locate targets within an image (precise task), looked at the image with no goal (unprecise task) or fixated on a cross (fixation task). In the pointing-on tasks, participants pointed a laser beam onto a small circle (2°) located in the middle of a larger circle (21°) containing the image. Result. As expected, postural sway was reduced in the precise task in contrast to the fixation task. Contrary to expectations, both precise and pointing-on tasks did not add their stabilizing effects. Furthermore, the pointing-on task almost did not influence body movements. The participants rotated their eye and head more and their upper back less in the precise visual tasks than in the unprecise visual tasks. Conclusion. The participants used a stabilizing coordination to fully explore images with eye and head rotations while stabilizing their body to perform precise gaze shifts. Our findings suggest that posture stabilization is performed to facilitate success in precise visual tasks more so than to perform pointing-on tasks.
2021a Bonnet et al., accepted in EJAP.pdf (363.92 Ko) Télécharger le fichier
hal-03049095 , version 1 (09-12-2020)
hal-03049095 , version 2 (18-05-2021)
hal-03049095 , version 3 (27-05-2021)
hal-03049095 , version 4 (01-07-2021)
hal-03049095 , version 5 (05-08-2021)
hal-03049095 , version 6 (08-09-2021)
  • HAL Id : hal-03049095 , version 3
Cédrick T. Bonnet, Déborah Dubrulle, Tarkeshwar Singh. In the upright stance, posture is better controlled to perform precise visual tasks than laser pointing tasks. European Journal of Applied Physiology, 2021, European Journal of Applied Physiology, 121, pp.893-901. ⟨hal-03049095v3⟩
136 Consultations
146 Téléchargements
