Deep phenotypic characterization of immunization-induced antibacterial IgG repertoires in mice using a single-antibody bioassay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications Biology Année : 2020
Antibodies with antibacterial activity need to bind to the bacterial surface with affinity, specificity, and sufficient density to induce efficient elimination. To characterize the antibacterial antibody repertoire, we developed an in-droplet bioassay with single-antibody resolution. The assay not only allowed us to identify whether the secreted antibodies recognized a bacterial surface antigen, but also to estimate the apparent dissociation constant (K D app) of the interaction and the density of the recognized epitope on the bacteria. Herein, we found substantial differences within the K D app /epitope density profiles in mice immunized with various species of heat-killed bacteria. The experiments further revealed a high cross-reactivity of the secreted IgG repertoires, binding to even unrelated bacteria with high affinity. This application confirmed the ability to quantify the anti-bacterial antibody repertoire and the utility of the developed bioassay to study the interplay between bacteria and the humoral response.
Heo Communications Biology 2020.pdf (2.37 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03054253 , version 1 (16-12-2020)
Paternité
Millie Heo, Guilhem Chenon, Carlos Castrillon, Jérôme Bibette, Pierre Bruhns, et al.. Deep phenotypic characterization of immunization-induced antibacterial IgG repertoires in mice using a single-antibody bioassay. Communications Biology, 2020, 3 (1), pp.614. ⟨10.1038/s42003-020-01296-3⟩. ⟨hal-03054253⟩
67 Consultations
39 Téléchargements
