Slide Reduction, Revisited—Filling the Gaps in SVP Approximation
We show how to generalize Gama and Nguyen's slide reduction algorithm [STOC '08] for solving the approximate Shortest Vector Problem over lattices (SVP) to allow for arbitrary block sizes, rather than just block sizes that divide the rank n of the lattice. This leads to significantly better running times for most approximation factors. We accomplish this by combining slide reduction with the DBKZ algorithm of Micciancio and Walter [Eurocrypt '16]. We also show a different algorithm that works when the block size is quite large-at least half the total rank. This yields the first non-trivial algorithm for sublinear approximation factors. Together with some additional optimizations, these results yield significantly faster provably correct algorithms for δ-approximate SVP for all approximation factors n 1/2+ε ≤ δ ≤ n O(1) , which is the regime most relevant for cryptography. For the specific values of δ = n 1−ε and δ = n 2−ε , we improve the exponent in the running time by a factor of 2 and a factor of 1.5 respectively.
Cryptographie et sécurité [cs.CR]
