A model intercomparison of atmospheric 137Cs concentrations from the Fukushima Daiichi Nuclear Power Plant accident, phase III: Simulation with an identical source term and meteorological field at 1-km resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Environment Année : 2020
The third model intercomparison project (MIP) for investigating the atmospheric behavior of atmospheric caesium-137 (137Cs) emitted from Fukushima Daiichi Nuclear Power Plant (FDNPP) (3rd FDNPP-MIP), Japan, in March 2011, was conducted. A finer horizontal grid spacing (1 km) was used than in the previous FDNPP-MIP (2nd FDNPP-MIP, Sato et al., 2018; 3 km) to evaluate the models’ performance for high-concentration events measured near FDNPP. Nine of the models used in the 2nd FDNPP-MIP were also used in the 3rd FDNPP-MIP, and all models used identical source terms and meteorological fields. The performance of the models was evaluated through a comparison with observational data. Our analyses indicated that most of the observed high atmospheric 137Cs concentrations (plumes) were reasonably well simulated by the models, and the good performance of some models improved the performance of the multimodel, highlighting the advantage of using a multimodel ensemble. The analyses also confirmed that the use of a finer grid resolution resulted in the meteorological field near FDNPP being better reproduced in the 3rd FDNPP-MIP, and the performance of the models was better than that of the 2nd FDNPP MIP. The good representation of the wind field resulted in the reasonable simulation of the narrow distribution of high deposition amount to the northwest of FDNPP and the reduction of the overestimation in deposition amount over the area to the south of FDNPP compared to the 2nd FDNPP MIP. In contrast, the performance of the models in simulating plumes observed over the Nakadori area, the northern part of Gunma, and the Tokyo Metropolitan Area (TMA) was slightly worse than in the 2nd FDNPP-MIP.
0000168985_001.PDF (11.51 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-03070582 , version 1 (15-01-2021)
Paternité
Yousuke Sato, Thomas Sekiyama, Sheng Fang, Mizuo Kajino, Arnaud Querel, et al.. A model intercomparison of atmospheric 137Cs concentrations from the Fukushima Daiichi Nuclear Power Plant accident, phase III: Simulation with an identical source term and meteorological field at 1-km resolution. Atmospheric Environment, 2020, 7, pp.100086. ⟨10.1016/j.aeaoa.2020.100086⟩. ⟨hal-03070582⟩
28 Consultations
35 Téléchargements
