An adjoint approach for the analysis of RANS closure using pressure measurements on a high-rise building - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Ben_Ali_et_al-JFM-2020.pdf (5.97 Mo) Télécharger le fichier
hal-03076369 , version 1 (16-12-2020)
hal-03076369 , version 2 (09-03-2022)
  • HAL Id : hal-03076369 , version 1
Mohamed Yacine Ben Ali, Gilles Tissot, Dominique Heitz, Sylvain Aguinaga, Etienne Mémin. An adjoint approach for the analysis of RANS closure using pressure measurements on a high-rise building. 2020. ⟨hal-03076369v1⟩
628 Consultations
124 Téléchargements
