Higher-order QR with tournament pivoting for tensor compression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We present in this paper a parallel algorithm that generates a low-rank approximation of a distributed tensor using QR decomposition with tournament pivoting (QRTP). The algorithm generates factor matrices for a Tucker decomposition by applying QRTP to the unfolding matrices of a tensor distributed block-wise (by sub-tensor) on a set of processors. For each unfolding mode the algorithm logically reorganizes (unfolds) the processors so that the associated unfolding matrix has a suitable logical distribution. We also establish error bounds between a tensor and the compressed version of the tensor generated by the algorithm.
FRENKIEL_David-hoqrtp.pdf (1.33 Mo) Télécharger le fichier
hal-03079236 , version 1 (17-12-2020)
hal-03079236 , version 2 (17-12-2020)
hal-03079236 , version 3 (18-12-2020)
hal-03079236 , version 4 (30-12-2020)
hal-03079236 , version 5 (02-02-2022)
  • HAL Id : hal-03079236 , version 2
David Frenkiel, Laura Grigori, Matthias Beaupère. Higher-order QR with tournament pivoting for tensor compression. 2020. ⟨hal-03079236v2⟩
539 Consultations
415 Téléchargements
