Existence of traveling wave solutions for the Diffusion Poisson Coupled Model: a computer-assisted proof - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The Diffusion Poisson Coupled Model describes the evolution of a dense oxide layer appearing at the surface of carbon steel canisters in contact with a claystone formation. It involves drift-diffusion equations on the density of species (electrons, ferric cations and oxygen vacancies), coupled with a Poisson equation on the electrostatic potential and with moving boundary equations. Traveling wave solutions are defined by stationary profiles on a fixed size domain with interfaces moving at the same velocity. In this paper, we present and apply a computer-assisted method in order to prove the existence of these traveling wave solutions. We also establish a precise and certified description of the solutions.
p2020_BCHZ.pdf (567.41 Ko) Télécharger le fichier
hal-03082893 , version 1 (18-12-2020)
hal-03082893 , version 2 (19-07-2021)
  • HAL Id : hal-03082893 , version 1
Maxime Breden, Claire Chainais-Hillairet, Antoine Zurek. Existence of traveling wave solutions for the Diffusion Poisson Coupled Model: a computer-assisted proof. 2020. ⟨hal-03082893v1⟩
223 Consultations
170 Téléchargements
