Self-supervised Nuclei Segmentation in Histopathological Images Using Attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Segmentation and accurate localization of nuclei in histopathological images is a very challenging problem, with most existing approaches adopting a supervised strategy. These methods usually rely on manual annotations that require a lot of time and effort from medical experts. In this study, we present a self-supervised approach for segmentation of nuclei for whole slide histopathology images. Our method works on the assumption that the size and texture of nuclei can determine the magnification at which a patch is extracted. We show that the identification of the magnification level for tiles can generate a preliminary self-supervision signal to locate nuclei. We further show that by appropriately constraining our model it is possible to retrieve meaningful segmentation maps as an auxiliary output to the primary magnification identification task. Our experiments show that with standard post-processing, our method can outperform other unsupervised nuclei segmentation approaches and report similar performance with supervised ones on the publicly available MoNuSeg dataset. Our code and models are available online at https://github.com/msahasrabudhe/miccai2020_self_sup_nuclei_seg/ to facilitate further research.
arxiv.pdf (928 Ko) Télécharger le fichier
hal-03087006 , version 1 (23-12-2020)
Mihir Sahasrabudhe, Stergios Christodoulidis, Roberto Salgado, Stefan Michiels, Sherene Loi, et al.. Self-supervised Nuclei Segmentation in Histopathological Images Using Attention. MICCAI 2020 - International Conference on Medical Image Computing and Computer-Assisted Intervention, Oct 2020, Lima, Peru. pp.393-402, ⟨10.1007/978-3-030-59722-1_38⟩. ⟨hal-03087006⟩
261 Consultations
296 Téléchargements
