Journal articles
Respiratory Monitoring Based on Tracheal Sounds: Continuous Time-Frequency Processing of the Phonospirogram Combined with Phonocardiogram-Derived Respiration
Abstract : Patients with central respiratory paralysis can benefit from diaphragm pacing to restore respiratory function. However, it would be important to develop a continuous respiratory monitoring method to alert on apnea occurrence, in order to improve the efficiency and safety of the pacing system. In this study, we present a preliminary validation of an acoustic apnea detection method on healthy subjects data. Thirteen healthy participants performed one session of two 2-min recordings, including a voluntary respiratory pause. The recordings were post-processed by combining temporal and frequency detection domains, and a new method was proposed—Phonocardiogram-Derived Respiration (PDR). The detection results were compared to synchronized pneumotachograph, electrocardiogram (ECG), and abdominal strap (plethysmograph) signals. The proposed method reached an apnea detection rate of 92.3%, with 99.36% specificity, 85.27% sensitivity, and 91.49% accuracy. PDR method showed a good correlation of 0.77 with ECG-Derived Respiration (EDR). The comparison of R-R intervals and S-S intervals also indicated a good correlation of 0.89. The performance of this respiratory detection algorithm meets the minimal requirements to make it usable in a real situation. Noises from the participant by speaking or from the environment had little influence on the detection result, as well as body position. The high correlation between PDR and EDR indicates the feasibility of monitoring respiration with PDR.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03093720
Contributor : Christine Azevedo Coste Connect in order to contact the contributor
Submitted on : Thursday, May 27, 2021 - 2:31:08 PM
Last modification on : Friday, December 3, 2021 - 12:13:18 PM
Long-term archiving on: : Saturday, August 28, 2021 - 7:24:39 PM
File
sensors-21-00099-v3.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Xinyue Lu, Christine Azevedo Coste, Marie-Cécile Nierat, Serge Renaux, Thomas Similowski, et al.. Respiratory Monitoring Based on Tracheal Sounds: Continuous Time-Frequency Processing of the Phonospirogram Combined with Phonocardiogram-Derived Respiration. Sensors, MDPI, 2021, 21 (1), pp.99. ⟨10.3390/s21010099⟩. ⟨hal-03093720⟩
Share
Metrics
Les métriques sont temporairement indisponibles
