Simultaneous Allocation and Control of Distributed Energy Resources via Kullback-Leibler-Quadratic Optimal Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
There is enormous flexibility potential in the power consumption of the majority of electric loads. This flexibility can be harnessed to obtain services for managing the grid: with carefully designed decision rules in place, power consumption for the population of loads can be ramped up and down, just like charging and discharging a battery, without any significant impact to consumers' needs. The concept is called Demand Dispatch, and the grid resource obtained from this design virtual energy storage (VES). In order to deploy VES, a balancing authority is faced with two challenges: 1. how to design local decision rules for each load given the target aggregate power consumption (distributed control problem), and 2. how to coordinate a portfolio of resources to maintain grid balance, given a forecast of net-load (resource allocation problem).Rather than separating resource allocation and distributed control, in this paper the two problems are solved simultaneously using a single convex program. The joint optimization model is cast as a finite-horizon optimal control problem in a mean-field setting, based on the new KLQ optimal control approach proposed recently by the authors.The simplicity of the proposed control architecture is remarkable: With a large portfolio of heterogeneous flexible resources, including loads such as residential water heaters, commercial water heaters, irrigation, and utility-scale batteries, the control architecture leads to a single scalar control signal broadcast to every resource in the domain of the balancing authority.
Fichier non déposé
hal-03094313 , version 1 (04-01-2021)
Neil Cammardella, Ana Bušić, Sean Meyn. Simultaneous Allocation and Control of Distributed Energy Resources via Kullback-Leibler-Quadratic Optimal Control. ACC 2020 - American Control Conference, Jul 2020, Denver / Virtual, United States. pp.514-520, ⟨10.23919/ACC45564.2020.9147402⟩. ⟨hal-03094313⟩
38 Consultations
0 Téléchargements
