Scaling-invariant functions versus positively homogeneous functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optimization Theory and Applications Année : 2021
Scaling-invariant functions preserve the order of points when the points are scaled by the same positive scalar (with respect to a unique reference point). Composites of strictly monotonic functions with positively homogeneous functions are scaling-invariant with respect to zero. We prove in this paper that the reverse is true for large classes of scaling-invariant functions. Specifically, we give necessary and sufficient conditions for scaling-invariant functions to be composites of a strictly monotonic function with a positively homogeneous function. We also study sublevel sets of scaling-invariant functions generalizing well-known properties of positively homogeneous functions.
scaling-invariance.pdf (383.61 Ko) Télécharger le fichier
hal-03104436 , version 1 (08-01-2021)
hal-03104436 , version 2 (07-09-2021)
Cheikh Touré, Armand Gissler, Anne Auger, Nikolaus Hansen. Scaling-invariant functions versus positively homogeneous functions. Journal of Optimization Theory and Applications, 2021. ⟨hal-03104436v2⟩
168 Consultations
556 Téléchargements
