A Comprehensive Framework for Saturation Theorem Proving
We present a framework for formal refutational completeness proofs of abstract provers that implement saturation calculi, such as ordered resolution or superposition. The framework relies on modular extensions of lifted redundancy criteria. It allows us to extend redundancy criteria so that they cover subsumption, and also to model entire prover architectures in such a way that the static refutational completeness of a calculus immediately implies the dynamic refutational completeness of a prover implementing the calculus, for instance within an Otter or DISCOUNT loop. Our framework is mechanized in Isabelle/HOL.
Logique en informatique [cs.LO]
