Function literals and value closures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2021
We propose the inclusion of simple lambda expressions into the C standard. We build on a slightly restricted syntax of that feature in C++. In particular, they only have immutable value captures, fully specified parameter types, and, based on N2735, the return type is inferred from return statements. This is part of a series of papers for the improvement of type-generic programming in C that has been introduced in N2638. Follow-up papers N2738 and N2737 will extend this feature with auto parameter types and lvalue captures, respectively.
n2736.pdf (752.79 Ko) Télécharger le fichier
hal-03106767 , version 1 (12-01-2021)
hal-03106767 , version 2 (10-06-2021)
Paternité
  • HAL Id : hal-03106767 , version 2
Jens Gustedt. Function literals and value closures: proposal for C23. [Technical Report] N2736, ISO JCT1/SC22/WG14. 2021, pp.55. ⟨hal-03106767v2⟩
82 Consultations
188 Téléchargements
