Topological Optimization of Under-Platform Dampers with Moving Morphable Components and Global Optimization Algorithm for Nonlinear Frequency Response - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Engineering for Gas Turbines and Power Année : 2021
GTP_Denimal_2021_MMC.pdf (2.6 Mo) Télécharger le fichier
hal-03106794 , version 1 (12-01-2021)
hal-03106794 , version 2 (12-02-2021)
hal-03106794 , version 3 (26-02-2021)
  • HAL Id : hal-03106794 , version 1
Enora Denimal, Fadi El Haddad, Chian Wong, Loic Salles. Topological Optimization of Under-Platform Dampers with Moving Morphable Components and Global Optimization Algorithm for Nonlinear Frequency Response. Journal of Engineering for Gas Turbines and Power, 2021. ⟨hal-03106794v1⟩
108 Consultations
310 Téléchargements
