Controllability of linear delay systems and of their sampled versions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on the controllability preservation through sampling of linear time-delay systems. We make use of a module theoretic framework acting as a unifying one for most of the existing delay system controllability notions. The controllability properties are envisioned through ring theoretic properties. Some illustrative examples complete the presentation.
S2405896320313999.pdf (291.47 Ko) Télécharger le fichier
hal-03108296 , version 1 (24-04-2023)
Paternité - Pas d'utilisation commerciale
Hugues Mounier, Silviu-Iulian Niculescu. Controllability of linear delay systems and of their sampled versions. IFAC 2020 - 21st IFAC World Congress, Jul 2020, Berlin / Virtual, Germany. ⟨10.1016/j.ifacol.2020.12.1032⟩. ⟨hal-03108296⟩
46 Consultations
8 Téléchargements
