Scaled, inexact and adaptive generalized FISTA for strongly convex optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Optimization Année : 2022
We consider a variable metric and inexact version of the FISTA-type algorithm considered in (Chambolle, Pock, 2016, Calatroni, Chambolle, 2019) for the minimization of the sum of two (possibly strongly) convex functions. The proposed algorithm is combined with an adaptive (non-monotone) backtracking strategy, which allows for the adjustment of the algorithmic step-size along the iterations in order to improve the convergence speed. We prove a linear convergence result for the function values, which depends on both the strong convexity moduli of the two functions and the upper and lower bounds on the spectrum of the variable metric operators. We validate the proposed algorithm, named Scaled Adaptive GEneralized FISTA (SAGE-FISTA), on exemplar image denoising and deblurring problems where edge-preserving Total Variation (TV) regularization is combined with Kullback-Leibler-type fidelity terms, as it is common in applications where signal-dependent Poisson noise is assumed in the data.
hal-03110210 , version 1 (14-01-2021)
Simone Rebegoldi, Luca Calatroni. Scaled, inexact and adaptive generalized FISTA for strongly convex optimization. SIAM Journal on Optimization, 2022. ⟨hal-03110210⟩
72 Consultations
0 Téléchargements
