Direct impact of gonadotropins on glucose uptake and storage in preovulatory granulosa cells: Implications in the pathogenesis of polycystic ovary syndrome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Metabolism Année : 2021
Background Polycystic ovary syndrome (PCOS) is often associated with higher levels of LH, and arrested ovarian follicular growth. The direct impact of high LH on FSH mediated metabolic responses in PCOS patients is not clearly understood. Method In order to investigate the impact of FSH and LH on glucose metabolism in preovulatory granulosa cells (GCs), we used [Usingle bond14C]-2 deoxyglucose, D-[Usingle bond14C]-glucose or 2-NBD glucose to analyse glucose uptake and its incorporation into glycogen. To reproduce the high androgenic potential in PCOS patients, we administered hCG both in vitro and in vivo. The role of IRS-2/PI3K/Akt2 pathway was studied after knockdown with specific siRNA. Immunoprecipitation and specific assays were used for the assessment of IRS-2, glycogen synthase and protein phosphatase 1. Furthermore, we examined the in vivo effects of hCG on FSH mediated glycogen increase in normal and PCOS rat model. HEK293 cells co-expressing FSHR and LHR were used to demonstrate glucose uptake and BRET change by FSH and hCG Results In normal human and rat granulosa cells, FSH is more potent than hCG in stimulating glucose uptake, however glycogen synthesis was significantly upregulated only by FSH through increase in activity of glycogen synthase via IRS-2/PI3K/Akt2 pathway. On the contrary, an impaired FSH-stimulated glucose uptake and glycogen synthesis in granulosa cells of PCOS-patients indicated a selective defect in FSHR activation. Further, in normal human granulosa cells, and in immature rat model, the impact of hCG on FSH responses was such that it inhibited the FSH-mediated glucose uptake as well as glycogen synthesis through inhibition of FSH-stimulated IRS-2 expression. These findings were further validated in HEK293 cells overexpressing Flag-LHR and HA-FSHR, where high hCG inhibited the FSH-stimulated glucose uptake. Notably, an increased BRET change was observed in HEK293 cells expressing FSHR-Rluc8 and LHR-Venus possibly suggesting increased heteromerization of LHR and FSHR in the presence of both hCG and FSH in comparison to FSH or hCG alone. Conclusion Our findings confirm a selective attenuation of metabolic responses to FSH such as glucose uptake and glycogen synthesis by high activation level of LHR leading to the inhibition of IRS-2 pathway, resulting in depleted glycogen stores and follicular growth arrest in PCOS patients
Chahal2021-Pre-print.pdf (9.24 Mo) Télécharger le fichier
hal-03112818 , version 1 (02-05-2024)
Nidhi Chahal, Anjali Geethadevi, Surleen Kaur, Ruchi Lakra, Anjali Nagendra, et al.. Direct impact of gonadotropins on glucose uptake and storage in preovulatory granulosa cells: Implications in the pathogenesis of polycystic ovary syndrome. Metabolism, 2021, 115, pp.1-15. ⟨10.1016/j.metabol.2020.154458⟩. ⟨hal-03112818⟩
91 Consultations
0 Téléchargements
