Analysing the HPKE Standard - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
Joël Alwen
  • Fonction : Auteur
  • PersonId : 1088731
Bruno Blanchet
Eike Kiltz
  • Fonction : Auteur
  • PersonId : 1088733
Benjamin Lipp
The Hybrid Public Key Encryption (HPKE) scheme is an emerging standard currently under consideration by the Crypto Forum Research Group (CFRG) of the IETF as a candidate for formal approval. Of the four modes of HPKE, we analyse the authenticated mode HPKE Auth in its single-shot encryption form as it contains what is, arguably, the most novel part of HPKE and has applications to other upcoming standards such as MLS. HPKE Auth 's intended application domain is captured by a new primitive which we call Authenticated Public Key Encryption (APKE). We provide syntax and security definitions for APKE schemes, as well as for the related Authenticated Key Encapsulation Mechanisms (AKEMs). We prove security of the AKEM scheme DH-AKEM underlying HPKE Auth based on the Gap Diffie-Hellman assumption and provide general AKEM/DEM composition theorems with which to argue about HPKE Auth 's security. To this end, we also formally analyse HPKE Auth 's key schedule and key derivation functions. To increase confidence in our results we use the automatic theorem proving tool CryptoVerif. All our bounds are quantitative and we discuss their practical implications for HPKE Auth. As an independent contribution we propose the new framework of nominal groups that allows us to capture abstract syntactical and security properties of practical elliptic curves, including the Curve25519 and Curve448 based groups (which do not constitute cyclic groups).
2020-1499v2.pdf (850.1 Ko) Télécharger le fichier
hal-03113251 , version 1 (18-01-2021)
hal-03113251 , version 2 (08-12-2021)
  • HAL Id : hal-03113251 , version 2
Joël Alwen, Bruno Blanchet, Eduard Hauck, Eike Kiltz, Benjamin Lipp, et al.. Analysing the HPKE Standard. [Research Report] IACR Cryptology ePrint Archive. 2020. ⟨hal-03113251v2⟩
346 Consultations
169 Téléchargements
