On Fixed-Time Interval Estimation of Discrete-Time Nonlinear Time-Varying Systems With Disturbances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this paper is to cope with estimation issues of discrete-time nonlinear time-varying systems with input and output. Inspired by [12], a new design technique of fixed-time observers is proposed. It relies on the use of past values of the output and the theory of the monotone systems to construct dead bit observer or fixed-time interval estimator depending on the absence or the presence of uncertainties. Finally, simulations are conducted to verify the effectiveness of the proposed schemes.
tdetal_acc20_final_v2.pdf (232.08 Ko) Télécharger le fichier
hal-03113667 , version 2 (28-02-2020)
hal-03113667 , version 1 (18-01-2021)
Thach Ngoc Dinh, Frédéric Mazenc, Zhenhua Wang, Tarek Raissi. On Fixed-Time Interval Estimation of Discrete-Time Nonlinear Time-Varying Systems With Disturbances. ACC 2020 - American Control Conference, Jul 2020, Denver, CO, United States. ⟨10.23919/ACC45564.2020.9147754⟩. ⟨hal-03113667v2⟩
192 Consultations
310 Téléchargements
