Protecting EST Payloads with OSCORE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2020
Göran Selander
  • Fonction : Auteur
Shahid Raza
  • Fonction : Auteur
  • PersonId : 1025309
Martin Furuhed
  • Fonction : Auteur
This document specifies public-key certificate enrollment procedures protected with lightweight application-layer security protocols suitable for Internet of Things (IoT) deployments. The protocols leverage payload formats defined in Enrollment over Secure Transport (EST) and existing IoT standards including the Constrained Application Protocol (CoAP), Concise Binary Object Representation (CBOR) and the CBOR Object Signing and Encryption (COSE) format.
draft-selander-ace-coap-est-oscore-04.pdf (87.18 Ko) Télécharger le fichier
hal-03120033 , version 1 (25-01-2021)
  • HAL Id : hal-03120033 , version 1
Göran Selander, Shahid Raza, Martin Furuhed, Mališa Vučinić, Timothy Claeys. Protecting EST Payloads with OSCORE: IETF Internet Draft. IETF Internet Draft, 2020. ⟨hal-03120033⟩
Collections
INRIA INRIA2
95 Consultations
138 Téléchargements
