On The Termination Problem For Probabilistic Higher-Order Recursive Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2020
In the last two decades, there has been much progress on model checking of both probabilistic systems and higher-order programs. In spite of the emergence of higher-order probabilistic programming languages, not much has been done to combine those two approaches. In this paper, we initiate a study on the probabilistic higher-order model checking problem, by giving some first theoretical and experimental results. As a first step towards our goal, we introduce PHORS, a probabilistic extension of higher-order recursion schemes (HORS), as a model of probabilistic higher-order programs. The model of PHORS may alternatively be viewed as a higher-order extension of recursive Markov chains. We then investigate the probabilistic termination problem-or, equivalently, the probabilistic reachability problem. We prove that almost sure termination of order-2 PHORS is undecidable. We also provide a fixpoint characterization of the termination probability of PHORS, and develop a sound (although possibly incomplete) procedure for approximately computing the termination probability. We have implemented the procedure for order-2 PHORSs, and confirmed that the procedure works well through preliminary experiments.
main.pdf (829.31 Ko) Télécharger le fichier
hal-03120859 , version 2 (25-01-2021)
hal-03120859 , version 1 (11-01-2022)
  • HAL Id : hal-03120859 , version 1
Naoki Kobayashi, Ugo Dal Lago, Charles Grellois. On The Termination Problem For Probabilistic Higher-Order Recursive Programs. Logical Methods in Computer Science, 2020. ⟨hal-03120859v1⟩
87 Consultations
155 Téléchargements
