A response to criticisms on “CMB constraints cast a shadow on CSL model” - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Physical Journal C: Particles and Fields Année : 2021
Our recent letter “Cosmic Microwave Background Constraints Cast a Shadow On Continuous Spontaneous Localization Models” (Martin and Vennin Phys Rev Lett 124:080402, 2020, arXiv:1906.04405) has recently been criticised in Ref. (Bengochea et al. Eur Phys J C 80:1021, 2020a) (see also Ref. Bengochea et al. 2020b, arXiv:2006.05313). In this reply, we explain why the arguments presented in those articles are either incorrect or a confirmation of the robustness of our results.
Martin-Vennin2021_Article_AResponseToCriticismsOnCMBCons.pdf (1.31 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03121071 , version 1 (26-01-2021)
Jérôme Martin, Vincent Vennin. A response to criticisms on “CMB constraints cast a shadow on CSL model”. European Physical Journal C: Particles and Fields, 2021, 81 (1), pp.64. ⟨10.1140/epjc/s10052-020-08811-0⟩. ⟨hal-03121071⟩
121 Consultations
63 Téléchargements
