Windowed total variation denoising and noise variance monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We proposed a real time Total-Variation denosing method with an automatic choice of hyper-parameter λ, and the good performance of this method provides a large application field. In this article, we adapt the developed method to the non stationary signal in using the sliding window, and propose a noise variance monitoring method. The simulated results show that our proposition follows well the variation of noise variance.
window_vt.pdf (305.67 Ko) Télécharger le fichier
hal-03122844 , version 1 (27-01-2021)
Zhanhao Liu, Marion Perrodin, Thomas Chambrion, Radu S. Stoica. Windowed total variation denoising and noise variance monitoring. 2021. ⟨hal-03122844⟩
203 Consultations
142 Téléchargements
