Confluence in UnTyped Higher-Order Theories by means of Critical Pairs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
User-defined higher-order rewrite rules are becoming a standard in proof assistants based on intuitionistic type theory. This raises the question of proving that they preserve the properties of beta-reductions for the corresponding type systems. We develop here techniques that reduce confluence proofs to the checking of various forms of critical pairs for higher-order rewrite rules extending beta-reduction on pure lambda-terms. The present paper concentrates on the case where rewrite rules are left-linear and critical pairs can be joined without using beta-rewrite steps. The other two cases will be addressed in forthcoming papers.
revision.pdf (803.72 Ko) Télécharger le fichier
hal-03126102 , version 1 (01-02-2021)
hal-03126102 , version 2 (12-05-2021)
hal-03126102 , version 3 (14-09-2021)
  • HAL Id : hal-03126102 , version 1
Gaspard Férey, Jean-Pierre Jouannaud. Confluence in UnTyped Higher-Order Theories by means of Critical Pairs. 2021. ⟨hal-03126102v1⟩
142 Consultations
283 Téléchargements
