MIMO Homogeneous Integral Control Design using the Implicit Lyapunov Function Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
In this paper, continuous and discontinuous integral controllers for MIMO systems are designed for a large class of nonlinear systems, which are (partially) feedback linearizable. These controllers of arbitrary positive or negative degree of homogeneity are derived by combining a Lyapunov function obtained from the Implicit Lyapunov Function (ILF) method with some extra explicit terms. Discontinuous integral controllers are able to stabilize an equilibrium or track a time-varying signal in finite time, while rejecting vanishing uncertainties and non-vanishing Lipschitz matching perturbations. Continuous integral controllers achieve asymptotic stabilization despite non-vanishing constant perturbations in finite-time, exponentially or nearly fixed-time for negative, zero or positive homogeneity degree, respectively. The design method and the properties of the different classes of integral controllers are illustrated by means of a simulation example.
IJRNC-IntC-ILF_28Enero2021_JM.pdf (581.96 Ko) Télécharger le fichier
hal-03131618 , version 1 (04-02-2021)
Angel Mercado-Uribe, Jaime Alberto Moreno Pérez, Andrey Polyakov, Denis Efimov. MIMO Homogeneous Integral Control Design using the Implicit Lyapunov Function Approach. International Journal of Robust and Nonlinear Control, 2021, ⟨10.1002/rnc.5474⟩. ⟨hal-03131618⟩
74 Consultations
213 Téléchargements
