Two dimensional Gross-Pitaevskii equation with space-time white noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Mathematics Research Notices Année : 2022
In this paper we consider the two-dimensional stochastic Gross-Pitaevskii equation, which is a model to describe Bose-Einstein condensation at positive temperature. The equation is a complex Ginzburg-Landau equation with a harmonic potential and an additive space-time white noise. We study the well-posedness of the model using an inhomogeneous Wick renormalization due to the potential, and prove the existence of an invariant measure and of stationary martingale solutions.
GibbsGP-2d.pdf (485.97 Ko) Télécharger le fichier
hal-03137755 , version 1 (15-02-2021)
Anne de Bouard, Arnaud Debussche, Reika Fukuizumi. Two dimensional Gross-Pitaevskii equation with space-time white noise. International Mathematics Research Notices, 2022, ⟨10.1093/imrn/rnac137⟩. ⟨hal-03137755⟩
153 Consultations
57 Téléchargements
