Computing L-Functions of Quadratic Characters at Negative Integers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We survey a number of different methods for computing $L(\chi,1-k)$ for a Dirichlet character $\chi$, with particular emphasis on quadratic characters. The main conclusion is that when $k$ is not too large (for instance $k\le100$) the best method comes from the use of Eisenstein series of half-integral weight, while when $k$ is large the best method is the use of the complete functional equation, unless the conductor of $\chi$ is really large, in which case the previous method again prevails.
hal-03139244 , version 1 (11-02-2021)
Henri Cohen. Computing L-Functions of Quadratic Characters at Negative Integers. 2021. ⟨hal-03139244⟩
38 Consultations
0 Téléchargements
